home welder set up
发表于 2021-9-1 00:54:30 | 显示全部楼层 |阅读模式
I am currently taking welding classes and want to have a home based welder to work with and do small projects on the side. I'm interested in TIG welding but having a stick for heavy stuff would be nice as well.Does anyone recommend a particular model or size? Im looking at under 800.00 ready to go.I hope this thread does not spark a heated miller/lincoln debate. . . resist the temptation to highjack it.Thanks-Mr. Avery
Reply:It's going to be tough to find a TIG/Stick combo, from the big 3, for $800 ready to go...unless you buy used. Buying used, it's probably going to lead you into the direction of something between 15 and 30 years old. Nothing wrong with an old Miller, Hobart or Lincoln but if you want new, you might have to hit up the import models. Giant guy on here sells those models.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:How about a Lincoln -miller -hobart debate. Just kidding, but I know you could get a nice wire machine and a stick machine from TSC for that kind of money . No tig though.TSC has the best prices around my area on Hobart equipment.Research alot of places and prices and see what the guys here come up with too.Good Luck and happy welding.pro-level dumpster diver                                     Hobart 125EZ
GMT+8, 2025-12-20 10:03 , Processed in 0.127611 second(s), 18 queries .
