plasma cutting torches
发表于 2021-9-1 00:54:28 | 显示全部楼层 |阅读模式
I'm looking into getting a plasma cutting torch. what would be the best one for around $500? i am only going to be cutting metal a half inch or less. i just don't want one thats going to break right after the warranty goes bad. thanks,whitesid
Reply:id like to find one of them 500 dollar ones too.ha ha ha ha
Reply:http://cgi.ebay.com/Dual-Voltage-50A...QQcmdZViewItemtheres a few cheaper ones on ebay but i don't know how good they are.
Reply:i bought a cutmaster 38 and am pretty happy with it. it was a lot more than 500. i dont know much about the china ones, maybe someone else will chime in.
Reply:There's a whole lot of torches available for under $500.   Now if you want the power supply and the torch for that amount of money, to cut 1/2", if you're looking for new, good luck!   Try looking on Craig's List for a used one...MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Originally Posted by whitesidI'm looking into getting a plasma cutting torch. what would be the best one for around $500? i am only going to be cutting metal a half inch or less. i just don't want one thats going to break right after the warranty goes bad. thanks,whitesid
Reply:Consider an oxy/ acetalene unit if its for occasional use and in that price range.  I don't yet have a plazma cutter, but have pretty good luck with a torch and a grinder, but it takes a little longer and don't get the clean cut of course.
Reply:Originally Posted by whitesidhttp://cgi.ebay.com/Dual-Voltage-50A...QQcmdZViewItemtheres a few cheaper ones on ebay but i don't know how good they are.
Reply:Many years ago a American company made a plasma torch that worked when fitted to any dc welding set with high frequency.I fitted one to a Miller 330 it worked well,im sorry i cannot the name,perhaps other members might recall this.
Reply:Now THAT sounds very interesting....MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-20 09:59 , Processed in 0.095003 second(s), 18 queries .
