Need to make a decision bout welders
发表于 2021-9-1 00:54:28 | 显示全部楼层 |阅读模式
Hi yall and Merry Christmas.. I've been welding for about 10 years now--welding our own frames for horse barns, indoor arenas, garages, shop buildings, and have built alot of fences out of oil pipe(2 3/8 and 2 7/8).  I have a Trailblazer 302 and it works like a charm.  Question is I'm headed to the oil field/pipeline(don't wanta cause a ruckus between the two) do I need to get a Miller Pro 300, Miller PipePro or will me little 302 be enough for now?  Any input would be greatly appreciated.
Reply:Check out the miller forum down below,Some one started the topic already and hopefully will get some more replies from actual pipeline welders.pro-level dumpster diver                                     Hobart 125EZ
Reply:Welcome and in the Pipeline or Oil Patch 1/8 6010 and 5/32 7018 are used most, so if your machine is good for that and you like it?  Go for it.   JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
GMT+8, 2025-12-20 10:03 , Processed in 0.103625 second(s), 18 queries .
