I am going to purchase a MIG
发表于 2021-9-1 00:54:27 | 显示全部楼层 |阅读模式
I am going to purchase the miller 140 with autoset. I am a little nervous. This is my first welder and obviously a big purchase.What are some things I should know.Things I CAN't do with this welder..Things I WILL be able to do with this welderPlease please let me know.
Reply:Originally Posted by pyroracing85This is my first welder and obviously a big purchase.What are some things I should know.Things I CAN't do with this welder..Things I WILL be able to do with this welder
Reply:If you are asking for advice, you need to tell us what you want to do.  JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:That is a really good point. A 140 i would say should weld up to 1/4 steel pretty easy with out any type of bevel. You are pretty limited to transfer modes. You won't be able to spray transfer or globular transfer. you really should do more research and make sure that machine is right for your needs. --Gol'
Reply:Originally Posted by weldgaultIf you are asking for advice, you need to tell us what you want to do.  John
Reply:Duty cycle is a concern, but it can be worked around.  Machines that small are for gauge metal and the like....They are intended for the weekend welder to make widgets and lawn ornaments, minor repairs around the house - wine racks, newspaper stands, crafts, etc.If your intentions are much more than that, it would be in your best interests to consider a larger machine.Are you able to inform us as to what materials you are planning to work with??? A little more information is required to see if the 140 will be able to do what you want.Last edited by Black Wolf; 12-26-2007 at 02:08 PM.Later,Jason
GMT+8, 2025-12-20 09:57 , Processed in 0.291554 second(s), 18 queries .
