Newbie here, any all in one machines? MIG/TIG/Stick?
发表于 2021-9-1 00:54:25 | 显示全部楼层 |阅读模式
I was wondering about availability and cost of all in one type machines. I was going to buy a small mig, but would like the option of Tig and maybe stick. I wouldnt mind spending a bit more for a multi proccess machine, but is it worth it? I dont need huge amperage, and it will be run on 220V at my house. I would like to weld aluminum also, but I'm not sure of the machine requirements, like frequency, square wave, etc. Very new at this. Dads a retired pro, but I'm just learning at 35, go figure... We're going to be building some aluminum work stands from box tubing, and were thinking of renting a machine. I'd rather just buy a machine that can do it all. Sorry for the rambling. Any tips or advice, links to articles, etc is greatly appreciated!Thanks!Chris
Reply:Mig is a constant voltage power sorce and STICk and Tig is constant currant --Gol'
Reply:Thanks, So is there no such animal? I guess I have seen stick /tig machines, but not all three in one unit?
Reply:Check Miller,Lincoln or HTP 's web site. They do make a multi process machine,But I think it is a DC only machine. That will limit you on your tig for alu.   Kevin    Try this link:http://www.htpweld.com/products/mts/index.htm     Hope it worksLast edited by mopar74; 12-27-2007 at 02:23 PM.
Reply:Originally Posted by H20ENGThanks, So is there no such animal? I guess I have seen stick /tig machines, but not all three in one unit?
Reply:Yup, I build them. Look into the Miller XMT350 Inverters.
Reply:Originally Posted by pyroracing85no, because stick/tig both use rods. However, mig uses wire and gas.
Reply:I have the Esab Multi Master 260 and love it.
GMT+8, 2025-12-20 10:00 , Processed in 0.072737 second(s), 18 queries .
