Tube alignment question...
发表于 2021-9-1 00:54:18 | 显示全部楼层 |阅读模式
I have been doing a lot of welding of tubing and was wondering what the best way to fixture tubing at various angle would be.  I see there are "jigs" that you can get for 90* assembly.......but do they make one that is adjustable 0-90 that you can use for holding the pieces during welding?  In other words if I wanted to put two tubes together at 51.5*, you could set it to that angle, then notch the tubes...put them in it...tighten it down on the tubes and weld the two together with worry of it pulling out of form.  Thanks.Best Times with 434 Naturally Aspirated Vette60 - 1.261/8 -  6.37@ 107.25 MPH 1/4 - 10.08 & 134.9MPH1/4 - 9.60@144MPH
Reply:Like these?http://www.lowbucktools.com/clamp.htmlYou could probably make one with a degree wheel.PatrickLincoln 175HD
Reply:Originally Posted by PatrickJLike these?http://www.lowbucktools.com/clamp.htmlYou could probably make one with a degree wheel.
GMT+8, 2025-12-20 11:40 , Processed in 0.085336 second(s), 18 queries .
