Best Wire Size
发表于 2021-9-1 00:54:14 | 显示全部楼层 |阅读模式
What is the best wire size to feed through the 125, 130 size migs? I have read where alot state a certain size for certain size welders typically does better and puddle wetting and performance. Thank you whitey
Reply:.023 which is the same as .024 or .025.  This will give you the most versatility from your machine.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Actually, for light fabrication, a .030 wire is more suitable. I'll tell you why.A .023 wire is realistically only suitable for material in the 22 ga. - 18ga. A .030 wire is suitable for material in the 22ga. (.031) - 1/8 (.125) range. A .035 wire is suitable for material in the 18ga. (.050) - 1/4 (.250) range. Most LWS's will be able to tell you this or you can consult your local Airgas which will supply you with a chart. Using .023 wire for anything more than the recommended can lead to bad penetration and an improperly filled (read: single pass) weld.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
GMT+8, 2025-12-20 10:16 , Processed in 0.089160 second(s), 18 queries .
