Miller Big 40 wont excite
发表于 2021-9-1 00:54:11 | 显示全部楼层 |阅读模式
Forgive me if this is not the right place to post.I have a Miller big 40...prolly alate 80's model...it has the red seal motor with coil and distributor, if that helps.The motor runs fine, but has no power to the leads or to the 110 outlet.Its been about 6 months since I've welded with it, it welded fine before that. What might be causing this and a ball part cost on fixing it.Thanks,Sam
Reply:Circuit breaker tripped?  Mouse chewing on wires?  Brushes not contacting?MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-20 10:23 , Processed in 0.068625 second(s), 18 queries .
