Maxstar 200 conversion to MIG
发表于 2021-9-1 00:54:05 | 显示全部楼层 |阅读模式
I have a Maxstar 200dx machine.Is there a MIG spool gun that I can buy to run off my Maxtor machine?  Is there any adapters/ conversions that can be made to make this work?Any help is greatly appreciated, thank you.
Reply:Your Maxstar has constant-current output.  Mig is normally done in constant-voltage output.  You will need a wire feeder that is made to run on constant current.  I think the Lincoln LN25 can do that.  There are others, but I don't remember which ones they are.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Thank you for your reply DesertRider33.I have emailed Miller if anything from their product lineup will enable me to use my Maxstar as MIG, I got a negative responce from them.I have looked into Lincoln LN25 feeder that you suggested and I have couple of questions.  When it says it works of the ark? and doesnt need any other power source? Does that mean I hook it directly to where I normally hook the torch and go with it?Also, I switch polarity when I go between Tig and stick, in what mode do I need to run when (and if) I buy something like LN25?  This unit is kinda pricey even for used, but I'm open to options.thanks for the help.
Reply:The Lincolin wire feeder is a great item. Any wire feeder that is VOLTAGE SENSING is what you need. Dont waste any money on a regular one it just wont work. Steel Thunder Welding LLC. St. Thomas VI USAMM350PBOBCAT 3MAXSTAR 150 STH375 EXTREME PLASMA6.5 HP COMPRESORDEWALT 18, 24, AND 36 VOLTO/A TORCH SETAND SO MUCH MORE I DONT REMEMBERALL IN MY 2005 2500HD EXTENDED CAB L/B
Reply:Offrdfun73,When you say a "regular one"  I assume you mean a wire feeder that is not Voltage Sensing?  What is a difference between the two?And besides lincoln, do you know any other brands that are "voltage sensing"Thanks for the help.
Reply:The 'regular feeder' Offroad referred to is one that connects to the remote control receptacle on the power source.  The voltage-sensing feeder connects on the weld output cable only.  MIG (solid wire and sheilding gas) is electrode-positive, meaning connect the feeder/torch to the positive weld output cable.  For flux-core wire welding, connect torch/feeder to the negative output cable.   There are some Miller feeders that are compatible with constant-current and are remote-control operated as well.  If I am not mistaken, the XR push-pull feeder/torch I have here are for both constant-voltage and constant-current, though I have only used it on constant-voltage.   The LN25 I believe can be used on constant-current or constant-voltage and is a voltage-sensing feeder but can also run on remote control when used with an optional remote-control kit from Lincoln.    Other voltage-sensing feeders are the Miller Suitcase Extreme/VS series, but I do not know if they can be used with constant-current.  There is also a Suitcase RC series for remote-control use only.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:DesertRider33,Your post is very informative thank you.  How come when I contacted Miller they said that nothing in their product line will work with the Maxstar for MIG?  Before I buy something this expensive, I want to have complete assurance that it will work.
Reply:If you can, before you buy a wire feeder and run it off your machine, try it first.  Its nothing great trying to use a machine to control the welding voltage.  LN-25 has a CC/CV switch inside it.  I have 2 of them.  I tried it and a Hobart Hefty wire feeder, both worked but not well at all.   Stick welding is at about 27 to 32 volts at a constant current level regardless of the voltage.  MIG short circuit welding is about 15 to 21 volts at a constant set voltage regardless of the current.Where ya from?  Come and try one out.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Originally Posted by dobehapDesertRider33,Your post is very informative thank you.  How come when I contacted Miller they said that nothing in their product line will work with the Maxstar for MIG?
Reply:I'm in Charlotte NC.  Thank you for the offer.    David, when you said it worked but not as well... could you explain how it worked and what didnt work too well?  I assume you ran your feeder on constant current - which gave you mixed results?DR33, I have read your gun conversion thread, very nice.
Reply:Originally Posted by dobehapDR33, I have read your gun conversion thread, very nice.
GMT+8, 2025-12-20 10:37 , Processed in 0.130709 second(s), 18 queries .
