Lens glare
发表于 2021-9-1 00:54:01 | 显示全部楼层 |阅读模式
I was wondering what everybody does about glare on the inside of their welding hoods.  I get bad glare from the overhead lighting in my shop.  It makes it hard to see while TIG welding small stuff.  I have been using a scrap of Nomex cloth taped to the back of my helmet.  Just wondering if there is any thing out there that is better. Thanks in advance.
Reply:i have auto darkening lights in my shop.  i have used a towel in the past when the sun was the culprit.  just kidding about the lights
Reply:i used a piece of an old welding jacket(green cotton) cut into a rectangle about 14 in x 24in. i put 4 snap studs along the top back of the helmet and maching snaps on the fabric. when you're welding it lays over your shoulders.if you don't need it you just un snap it.
Reply:Turn the lites off or put your Hugh Jarse in the way.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterTurn the lites off or put your Hugh Jarse in the way.. ...zap!
Reply:Just kiddin' with ya!  ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:It just stopped bothering me after a while.  Don't even notice it now, unless someone walks up behind me.
Reply:I have a very low-tech approach to it-  I just keep adjusting position untill I can see.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:When faced with this difficult problem, the true professional simply memorizes the shape of the part, closes his eyes, and welds by sound.
Reply:Tig weld by sound?  I think im gonna have my hearing checked Victor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:Just pick up the narrowest helmet you can find and put your lense assembly in it, I also hate glare on the inside of my lense.Anything worth doing is worth doing RIGHT
Reply:Originally Posted by clark-kentskiTig weld by sound?  I think im gonna have my hearing checked
Reply:TIG is very quiet, like a little girl whispering.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:The only sound tig makes is when you hit the tungestion on the filler/base material..Then it makes like a "crack" sound.."I heard that!!"...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:The crack right before the burning sensation in your filler hand, then you open your eyes and see your hand on fire...
GMT+8, 2025-12-20 11:49 , Processed in 0.324851 second(s), 18 queries .
