Any body having prob's
发表于 2021-9-1 00:53:58 | 显示全部楼层 |阅读模式
with there A/D len's mine is a trade'smen, protecter plate is clean nothing blocking the senser, welding out in the shop, fluoresent lighting, temp inside was mid thirty's. I would be welding and it would just start flashing me.
Reply:I had some trouble like that last winter when it was cold where I was welding.I had to get new batteries and was good to go.I started with the helmet warm and after it would cool down outside I would get flashed or it wouldn't darken when I started a weld.It was a speedglass and my son had always used it inside before.The batteries had to be about 3 yrs old I'm guessing.pro-level dumpster diver                                     Hobart 125EZ
Reply:my bad, mine don't use batteries
Reply:Some Solar use batteries as a back up, but batteries have to be changed, as in a flashlite.   JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:I have an auto dark helmet and if I leave it lay too long between use it won't work. Then if I lay it in the sun a while it will charge up and then will work. Now during long non use periods I set it in a window where the sun will hit it and then it stays charged up.Welder- Miller Thunderbolt AC 225-DC 150 Plasma cutter, Miller Spectrum 300O/P torch- Victor 100
Reply:the temp has a lot to do with it it may only be rated to run well when its like 40 above and better some lenses are good to -23 below see if you can find out the temp ratings on yours hope that helps
Reply:Sometimes I get in positions where my arm or hand block the arc, then i get flashed, occasionally-depends on sensitivity.
Reply:I didn't know they have temp rate's I will check that out thank you.
GMT+8, 2025-12-20 10:27 , Processed in 0.092760 second(s), 18 queries .
