Control Pedal Question (Miller Maxstar 150)
发表于 2021-9-1 00:53:55 | 显示全部楼层 |阅读模式
Hello guys,  I ordered remote pedal yesterday and should be on the way anytime soon.  I already read manual of both pedal and Maxstar 150 but one thing is not very clear.  Would the control pedal go from 0 - 150 amps?? or would it still depend on the dial setting on the unit?? like  if I set it to 100 amps, full pedal would only max at 100.  Pedal manual says look at welder for specific answer but the welder manual doesn't really specify that.  Thanks in advance// Jo_______Miller Maxstar 150 STLLincoln ProMig 140Hobart Handler 210
Reply:Goes from 0 to the panel setting on the machine.
Reply:Thanks!!_______Miller Maxstar 150 STLLincoln ProMig 140Hobart Handler 210
GMT+8, 2025-12-20 10:27 , Processed in 0.146447 second(s), 18 queries .
