Stoody brand "Stoodite" 6-m
发表于 2021-9-1 00:53:54 | 显示全部楼层 |阅读模式
What is the correct amperage for this type of wire? and also I was told to use pure argon. I am currently using 98/2. I was told by omeone else that Argon would make the problem worse because argon burns much hotter than 98/2. To me it seems 98/2 would be hotter because of the oxygen. I don't know. My problem is I keep burning up tips 5minutes of weld time and stop and change tips. I have tried loosenig the tension on my feed rollers and tightening the rollers. I have tried over sized tips, nothing seems to help. does anyone have any suggestions?
GMT+8, 2025-12-20 10:26 , Processed in 0.145818 second(s), 18 queries .
