Ammonia pipe?
发表于 2021-9-1 00:53:53 | 显示全部楼层 |阅读模式
Has anyone here heard of ammonia pipe?Its for the restaurant business...right? weld it like you own it
Reply:i think.... its use for the frig/koolers, freezer systems,, they use it like freon i think
Reply:Originally Posted by prop-doctori think.... its use for the frig/koolers, freezer systems,, they use it like freon i think
Reply:large AC systems also use it.Be careful that is nasty stuff!Me!
Reply:Lewray, yes, it is a cooling system. Works on the same principles as freon, basically. But it often heats with nat. gas. Yes, it is some caustic nasty stuff. I have, in the past, pulled sections of coils from big chiller systems, and sent them out to be repaired and pressure tested. I have never welded it myself. I am not sure of how much cleaning needs to be done before you can weld on it. We avoided it because the hazard rating was pretty high, and the boss had a shop who specialized in it.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:Thanks guysThat explains some.... there was an add in the paper lookin for folks that had experience. weld it like you own it
Reply:Had a job with Kroger once.  Never again.  Just the corrosion factor on my equipment was bad enough to keep me from fooling with it again.  To be honest though, I had no idea what I was getting into.Anything can be fabricated on-site. Truth is fabricated online.
Reply:Ammonia pipe.....?Sch. 80 is type, use no Teflon on the threaded, softset pipe dope. And weld where applicable.Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:We do ammonia at a couple of different plants. A106 seamless pipe 3,000lb fittings. Insurance for working on ammonia is unreal. It cost more than insurance for power house work.
Reply:Originally Posted by SandyYep, it's for anyone using freezers and cold storage. And getting to be more politically sensitive.
Reply:RV:  ice boxes/fridges sometimes use it. makes the fridge work when on propane and must be level ( the camper)
Reply:Originally Posted by txfireguy2003Just curious what you mean here.  Freon leaks and goes into the atmostphere, destroys some ozone...yadda yadda yadda.  Amonia leaks, settles in low lying areas and, in high enough concentrations, kills people.  That is bad stuff.  Around here, farmers pump it into the ground as fertilizer.  But the biggest problem with the amonia around here is that it is always leaking, because the meth cooks are always trying to steal it and leaving the valves open.
Reply:Yup, something about it makes the meth cooks love it.  There have been a couple dopers shot by the area farmers when they got caught stealing the stuff.  Serves 'em right if you ask me...and the new "Castle Doctrine" law in Texas means that the farmer is in the clear.  If he's on your PROPERTY and stealing, you can legally shoot him in Texas now...Yessir, while other states are abolishing the death penalty, mine's putting in an express lane!Contact me for any metal polishing needs you may have, my avatar is a pic of a standard, painted fire axe that I ground, sanded polished and buffed to a mirror finish.
GMT+8, 2025-12-20 10:27 , Processed in 0.096173 second(s), 18 queries .
