Rod Bending
发表于 2021-9-1 00:53:51 | 显示全部楼层 |阅读模式
Does anybody know how I can bend rod up to 1/4" thick?I seen this on MSChttp://www1.mscdirect.com/CGI/NNSRIT...MT4NO=37092671but it only goes up to 3/16"
Reply:If bending then try the link below, the sell 2 models.  http://www.northerntool.com/webapp/w..._240604_240604
Reply:Originally Posted by tapwelderAre you trying to bend or roll.  If bending then try the link below, the sell 2 models.  If rolling then HF has a cheap ring roller that will roll 1/4 bar max capacity.http://www.northerntool.com/webapp/w..._240604_240604
Reply:yeah,  from aprox. 2'' radius up to whatever you need.FYI,I edited my post, after studying the link you posted and determining it was a bender.
Reply:Find an anvil and use a hammer ,learn how to be a blacksmith.  hehe.Life is tuff,so be sharp  lincoln sp 100  cutmaster101  miller bobcat  miller 250 mig  $thousands in snapon
Reply:This  is how I bend nearly everything.  This is 5/16" rod.  I have several RR track anvils set at various distances.  Heavier stock gets a heavier hammer.  I bend 1" stuff regularly.  On circles. once i get it over 150deg I place a die in the bend and pound the bar or rod around it.  I might be a little "old school".  Great strees relief and my forearms look like Popeye's. Attached ImagesAnything can be fabricated on-site. Truth is fabricated online.
Reply:if it's 1/4" round stock what I do is draw the project on a table and tack pipe at the bends(depending on the radius I want) and clamp one end and start bending it around the lugs sometimes you need some manipulation with a hammer though and or some heat
Reply:Here is the small bender I use for all the small round bar projects I have posted. I could take some better pic's of it and measurments for you if you like so you can build your own. Let me know.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:thats a nice bender jamlit
Reply:Originally Posted by jamlitHere is the small bender I use for all the small round bar projects I have posted. I could take some better pic's of it and measurments for you if you like so you can build your own. Let me know.
GMT+8, 2025-12-20 11:46 , Processed in 0.095211 second(s), 18 queries .
