Best welding book
发表于 2021-9-1 00:53:50 | 显示全部楼层 |阅读模式
Does anybody know of a GOOD welding book that teaches basics of welding and then another book that teaches advanced welding?Please let me know.
Reply:Lincolns 'metals and how to weld them' and Lincolns 'welding procedure' books.
Reply:Lincolns "Procedure Handbook of Arc Welding" is the best I have seen, pretty much covers it all, and tells you where to go for additional and more in depth info.The difference between art and craft is the quality of the workmanship. I am an artist.
Reply:The best book is "The one you "write" yourself thru experience".....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:As far as basics go with pictures of techniques, typically mistakes, etc, "Welding Principles and Applications" by Jeffus is a good one as well.  For the price that the Lincoln books cost, they're a must have though, especially Metals and How to Weld Them.
Reply:Check your local library for "the Science And Practice Of Welding" by A. C. Davies. Lots of good stuff. If it can be welded he tells how to.
Reply:What Supe said! Has it all and then some!
Reply:Originally Posted by SupeAs far as basics go with pictures of techniques, typically mistakes, etc, "Welding Principles and Applications" by Jeffus is a good one as well.  For the price that the Lincoln books cost, they're a must have though, especially Metals and How to Weld Them.
Reply:All the good things in life are friggin' expensive!I think that's how the saying goes...
Reply:Originally Posted by daddyAll the good things in life are friggin' expensive!I think that's how the saying goes...
Reply:Well I purchased the book. It should be here around next week some time..I hope it is as good as you guys say it is..
Reply:http://search.barnesandnoble.com/boo...31131517&itm=2Here is one I like and have.  It's a very good basic reference.  There are lots of freebies that are very good also.  Miller has a whole slew.http://www.millerwelds.com/education...pamphlets.htmlThen there are the AWS manuals...they are the big guns.  I have seen a couple of older issues...they have it all, but are not terribly affordable.Smithboy...if it ain't broke, you ain't tryin'.
Reply:The companion book  Welding Fabrication and Repair is also a good one.DennisThermal Arc 185-TSWMillermatic Challenger 172VictorO/AAtlas Craftsman 12 by 24 LatheEsab PCM-875Wholesalem Tool Mill-Drill
Reply:Best book I've seen for pressure pipe......Pipe Welding Procedures, Second Edition, by Rampaul.
GMT+8, 2025-12-20 11:41 , Processed in 0.129242 second(s), 18 queries .
