exhaust cut out
发表于 2021-9-1 00:53:50 | 显示全部楼层 |阅读模式
Has anyone evr welded a cast iron exhaust cut-out made by Mr Gasket? Looking for the correct process. Heres a pic Attached Images
Reply:i would braze it on or tig it with silicon bronzeChuckASME Pressure Vessel welder
Reply:Why bother welding it, its only gonna work for a week and you'll end up having to cut it out.I like to party!
Reply:True Captin Willy I have put these on 3 cars for friends back in the states and only one lasted more than a month and it leaked and would not pass inspection. They are aperintly not allowed in Missouri. I used 1/8" 6011. It welded just fine and did not crack but the valve would stick. The guy that had the one that lasted would work the valve 2 or 3 times everytime he started the car but after 3 or 4 months it leaked bad. Steel Thunder Welding LLC. St. Thomas VI USAMM350PBOBCAT 3MAXSTAR 150 STH375 EXTREME PLASMA6.5 HP COMPRESORDEWALT 18, 24, AND 36 VOLTO/A TORCH SETAND SO MUCH MORE I DONT REMEMBERALL IN MY 2005 2500HD EXTENDED CAB L/B
Reply:Not for me fellas just trying to help someone out is all. I personally wouldn't want it.
GMT+8, 2025-12-20 11:46 , Processed in 0.066662 second(s), 18 queries .
