compartment doors and frames
发表于 2021-9-1 00:53:43 | 显示全部楼层 |阅读模式
I'm thinking of building a flatbed for my ton truck. If I do it I'd like to make some compartments under the forward portion of the bed. It's an older truck ('86 GMC) so I'm not sure if off the shelf compartments are available (they'd need to be oddly shaped to clear the fuel tanks), so I was wondering if someone made std. doors and door frames so I could make a box to fit my space and use a nice water tight door.thanks.
Reply:I've built a lot of truck beds and never saw such a critter.The difference between art and craft is the quality of the workmanship. I am an artist.
Reply:I have a 76 dodge d100 long bed. It has a storage compartment under the passenger side. You would want it on that side to clear traffic. If you can find one. You would have to remake the door to fit your body lines. This might be what your talking about. For a flat bed you could make the whole thing. Is the tank out side the frame rails.Last edited by Hott Racing; 02-10-2008 at 10:08 AM.lincoln sp100miller syncrOwave 200 matobo grinders6 different torches for display  Learning the trade
Reply:Custom make your own boxes, that's what I do.  It's way cheaper than TSC.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Check this guy out:http://www.tomraperrvparts.com/parts...cat=308&page=1
Reply:Check this guy out:http://www.rvsurplussalvage.com/cata...x=0&search.y=0
Reply:Hey olddog, thanks for the links. May have just found a source for the obsolete part my buddy needs for his shower.The difference between art and craft is the quality of the workmanship. I am an artist.
GMT+8, 2025-12-20 10:27 , Processed in 0.090011 second(s), 18 queries .
