Trying to figure out English metal specs
发表于 2021-9-1 00:53:36 | 显示全部楼层 |阅读模式
Ok, I'm about to quote on a project that is currently being made in England.  The problem I'm having is the material specs - for instance, what is "EN3B"??  "Bright drawn steel angle"?
Reply:http://www.macreadys.co.uk/products/usaflat.htmlHope this helps you.
Reply:Ask these guys.http://www.ukwelder.com/forum/
Reply:Thanks, that does help.  I had pretty much assumed "bright drawn" referred to cold rolled; but I have not seen cold rolled angle before...  Thank you!
GMT+8, 2025-12-20 10:58 , Processed in 0.096022 second(s), 18 queries .
