hardfacing wire
发表于 2021-9-1 00:53:32 | 显示全部楼层 |阅读模式
i'm looking for a hardfacing wire that will hold up. i'v tried arctech,ronamatic,perfect pass. also i do more vertical welds with it. the flux cored wires seem to run better but not lasting. i'm hardfacing compaction wheels. they are used mostly in rock,sand,clay ect.  anybody have good wire?
Reply:Sounds like all the ingredients for a grinding stone there, i think I'm seeing the problem.Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:I've used Lincore 55 on those and got good results, good being a relative factor. Stoody 36 is a decent rod choice also....
Reply:stulz wire works for me. .045 21volts 270ipm vert. the welds arent pretty but they hold up."Retreat hell, were just fighting in the other direction"Miller Trailblazer 302, Extreme 12 VS, Dimension 400, Spectrum 375, HF 251D-1, Milermatic 251 w/ spoolgun  Hypertherm 1000Lincoln sp 1702000 F-450 to haul it
Reply:Try the McKay wire, or Stoody.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
GMT+8, 2025-12-20 10:58 , Processed in 0.099732 second(s), 18 queries .
