Penetration question
发表于 2021-9-1 00:53:31 | 显示全部楼层 |阅读模式
Hello all,When i was welding a 1/8 inch piece of flat stock i could see the burn on the back side of the piece.Then i set the machine for 1/4 inch and ran a bead on 1/4 inch stock and when it turned over i did not see any burn mark. Does this mean i did not get full penetration on the 1/4 inch piece? Thanks!
Reply:Yes, it does.
GMT+8, 2025-12-20 10:57 , Processed in 0.141182 second(s), 18 queries .
