Stud Welding Daily Test
发表于 2021-9-1 00:53:28 | 显示全部楼层 |阅读模式
I Have A Question About Doing Daily Test On Weld Studs For Embeds.  Is There A Place To Get A Preprinted Form Or Do I Just Make Up One Covering The Test And Procedures? We Weld Studs With Mig Welder For Embeds
Reply:if you are working to aws d1.1, then look in annex n. there is a pqr/wps form that allows the recording of this data.
Reply:Thanks for the help.  I guess we really need to spend the money and get the book and full specs.
Reply:if your going to be performing code work i highly recommend purchasing the code. it's much cheaper in the long run.
Reply:There is nothing better than a well documented procedure to code for covering your ***!
GMT+8, 2025-12-20 10:59 , Processed in 0.332291 second(s), 18 queries .
