Hobart Champion 8500 welder/ generator?
发表于 2021-9-1 00:53:27 | 显示全部楼层 |阅读模式
My buddy is looking at a lightly used Hobart champion generator/welder. It will be used for fixing things around the place and some mobile repair. He has a mill and will be doing small logging operations so this thing could really come in handy. The repair shop won't exactly be right down the road so reliability is a must. Not to mention that I will most likely use it once or twice so want to make sure that it's the right one.    ha ha... Any info is appreciated, thanks.
Reply:Oh yeah the asking price is $1600 is it worth it?
Reply:That price could be ok depending on how many hours are on the machine and its general condition. I believe that that's close to top dollar unless it's a really low time machine. If it has more than 1500 hrs it should be priced closer to $1000 in my opinion. More than 2000 hrs it should  be dirt cheap.
Reply:It's an excellent machine for general use. I used one in a heat exchanger shop on a rather large steam condenser using 3/16 7018. It's not meant for really heavy use though. Only has about a 60% duty cycle at around 200 amps. They sell new for about $2300 if that helps.The difference between art and craft is the quality of the workmanship. I am an artist.
Reply:This thing kicks butt! This Hobart welds way better than the Lincoln 250 tombstones at school. I would buy a Hobart champion in a heartbeat.
GMT+8, 2025-12-20 11:02 , Processed in 0.075878 second(s), 18 queries .
