Question for David
发表于 2021-9-1 00:53:27 | 显示全部楼层 |阅读模式
Are you using your LN-25 for the pulsed mig? If so I have another question.The difference between art and craft is the quality of the workmanship. I am an artist.
Reply:I have, but the LN9-GMA works better because the control cable.It says "Not recommended" in the manual.  I can see why.  I weld the wire to the tip a LOT.When I let go of the trigger, the welder is still welding and the arc wants to continue off the tip, so I have to pull the gun away.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Thanks, that told me what I needed to know.The difference between art and craft is the quality of the workmanship. I am an artist.
GMT+8, 2025-12-20 10:57 , Processed in 0.088668 second(s), 18 queries .
