innershield wire - 232 vs. 233
发表于 2021-9-1 00:53:23 | 显示全部楼层 |阅读模式
I'm working on getting certed for innershild wire.        I've been practicing w/ 233 instead of 232.     233 seems easier.     According to Lincoln 233 is equivelant to 232 for structural use.       Can anyone say anything different.      I'm not sure I believe it 100%.
Reply:Never used 233, but 232 is a bitch to run up hill.  It took me 1/2 a spool to get the hang of a 3F.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:As I understand it and from using all three the 233 is Lincolns answer to ESAB Coreshield 8.233 is a bit more like core8 than 232. 232 compaired to core 8 232 is "dirtier" more persnickety traps slag easer than core8. All three qualify for the same uses  all three are charrpy -20 or better. and can be used in place of 7018.
GMT+8, 2025-12-20 11:04 , Processed in 0.095273 second(s), 19 queries .
