I'm thinking of buying an LN-25 feeder. The main purpose will be innershield. I'm not real educated on this item as far as the difference between the older models and what extra features the new ones have, or if the new ones are as good. I'd like to hear any likes or dislikes anyones had with LN-25.
Reply:http://www.mylincolnelectric.com/Cat...eet.aspx?p=420K-428 Model for non gas shielded applications.http://www.mylincolnelectric.com/Cat...eet.aspx?p=421K-449 Model with gas contactor solenoid for use with shielding gas.http://www.mylincolnelectric.com/Cat...t.aspx?p=50474"New" LN-25 Pro Model.I have used the LN-25 over several years for GMAW, FCAW-SS, and FCAW-DS applications, in Short Circuit, Globular and Spray Arc modes of transfer. I have used them indoors, outdoors, and at minor elevations <50' and have had excellent results. I have used them for equipment repair and maintenance, and for building Oilfield Hauling equipment here in the Northern Alberta oilpatch. I have ran them off of engine driven welders both CC and CV, and off of inverters on CV with equal results. They simply get the job done, day in and day out.I have not had the opprotunity to use the new LN-25 Pro, but have been researching it for a new aquisition. My LWS is supposed to have one in soon that I can borrow and hang a licken' on, as they are also trying to sell me a new Ranger 305G to replace my Ranger 250.The LN-25 Pro has some neat features with the two step trigger interlock that I came to LOVE when using the LF-72 wre feeders, and also it has a built in flowmeter etc in the back of the case. Review the info for yourself and see if it is a better fit in your application. Just in case you didn't know, the MaxTrac drive system in the LN-25 Pro had been used in the PowerMig series and the LF-72 and LF-74 (to name a few) for several years now. The drive system is simple, and the tool-less drive roll changing is very handy.If you are still leaning towards the LN-25, I would suggest the K-449 so that you have the ability to switch to GMAW (hardwire), or "Outershield" FCAW-DS wire without paying for upgrades.Just my $.02Hope it helps.Last edited by Black Wolf; 03-01-2008 at 02:11 PM.Reason: Spelling.......darn batteries in my keyboard.Later,Jason
Reply:I have 2, both are about 20 years old. No contactor, just a gas valve. I paid Just over $1,000 for one new. I think they will keep going for ever. I have burned up a LOT of wire through one mostly hooked up to an engine drive and .045 wire.I know nothing about the PRO model.Its a great wire feed. Nuff said.DavidReal world weldin. When I grow up I want to be a tig weldor.
Reply:I own several LN -25's as well the Miller 12sv both have good and better pointsThe LN -25 fine money making machine I too would suggest the one with the on board contactor and gas valve.Jimmy
Reply:I too have an LN-25 and also a thermalarc Hefty. I use the LN-25 and someone else is stuck with the Hefty. That should tell you something. If I remember correctly if you don't have the contactor you always have a hot gun. I too would recommend getting the contactor and gas solenoid. Much cheaper than having it added later and it also gives you a lot more capability. My LN -25 is approximately 20 years old as well. Like anything I have ever had that said Lincoln on it if well cared for it seems to last forever.The difference between art and craft is the quality of the workmanship. I am an artist. |
