i finnially found a welding hood i like (huntsman)
发表于 2021-9-1 00:53:17 | 显示全部楼层 |阅读模式
a guy that just started with us has a huntsman 751 p. it is light and its smaller it fits up tight to your face and it has a 5x4.5 lens. i decided i want one. i went on the internet and found it and it says its for oxy ace cutting and welding only. now i know you dont want to weld over head 6010 with it as it is made of vulcanized fiber and most all i do is tig weld. what im asking is if i put my #11 shade in it i should be fine right. i really like this hood and i personally dont see anything wrong with it. i know a few old timers who swear by a huntsman but they use the ones with the lens that slides up inside it they had never seen one like this. does anyone on here use one or have any insight on them thanks for any help-BrettLast edited by scubaholic; 03-05-2008 at 08:45 PM.Reason: left out somethingComplete Fabrication Shop specializing in pipe fabrication. Also offering heavy steel fabrication and sheet metal work.
Reply:Some of the other welders at my old job liked the Huntsman fiber hoods.  I prefer Jackson but I do like the light weight of the fiber fixed lens hoods.  I don't know what model numbers they were.   They had the regular 2x4 fixed lens.   We were doing pulse mig on aluminum.  I don't see why there would be any problem using it for TIG.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:I had problems with my huntsman warping and letting light in around where the outer lense moves up and down. I have a fiber metal now, Yeah its more heavy but I dont mess around when it comes to my eye sight, I just wish they made one with the flip up 4x5 lense.
GMT+8, 2025-12-20 11:18 , Processed in 0.152468 second(s), 19 queries .
