inconel 601
发表于 2021-9-1 00:53:16 | 显示全部楼层 |阅读模式
i possibly have a job making some small pans and a rack. the material is inconel 601. i've never welded this before and was hoping for any input or help.  thanks     ps th thickness will be 1/16.
Reply:It should be pretty easy simular to welding stainless but has better puddle characteristics and controllability. It's somewhat hard to see but should weld up fine. I never welded 601 before but 625 and 718 I have. I'm just assuming since it's 600 series it would be simular to what I've welded in the past. You probably can use 625 wire for this.
Reply:sounds good. thanks for the input. i will give it a shot.
GMT+8, 2025-12-20 10:58 , Processed in 0.068436 second(s), 18 queries .
