TIG root and hot pass vs. Stick
发表于 2021-9-1 00:53:15 | 显示全部楼层 |阅读模式
I am new to pipe welding and was wondering what kind of work requires a tig root, or even tig all the way out, and what requires stick all the way out. What application is each used for.
Reply:What ever the procedure calls for.  There are many combinations of the two.   JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Originally Posted by weldgaultWhat ever the procedure calls for.  There are many combinations of the two.   John
GMT+8, 2025-12-20 11:18 , Processed in 0.089285 second(s), 18 queries .
