drive rolls
发表于 2021-9-1 00:53:08 | 显示全部楼层 |阅读模式
Does anyone know if the drive rolls in the hobart 187 are cast aluminum or plastic.also would like to know about the lincoln 180t drive rolls.thanks--mccoy
Reply:The Hobart drive wheels are metal not plastic.......not sure about the Linc.(pretty sure they are metal as well)...but I do know the Linc is hard to get the 10 lb spools of wire into and the adapter hits the door.....
Reply:The Lincoln drive rollers are hardened steel. I think most MIG machines are the same in this regard.
GMT+8, 2025-12-20 11:31 , Processed in 0.090515 second(s), 18 queries .
