Time for upgrade but!
发表于 2021-9-1 00:53:07 | 显示全部楼层 |阅读模式
I only have 220V @ 30 amps to deal with so obviously no big welder. So with that in mind can someone recommend a replacment to my hobart handler 140 that fits my power restraint?
Reply:TA-185 DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:I believe Lincoln's ProMig 180C uses a 30 amp 220 circuit. Hobart and Miller have models that do as well.The difference between art and craft is the quality of the workmanship. I am an artist.
Reply:HH210 will run just fine on that.....
Reply:Millermatic 180 will run on that with 10 amps to spare.  Millermatic 212 should run on 30 amps too.  My HTP MIG200 runs at max power on 30 amp breaker and has never blown the breaker.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:I run a 250 amp mig and 180 amp tig on 240v and 30amp haven't pop it yet I don't use the tig alot now but run the mig up near its full settings alot but our power runs the other way to you guys  sorry i couldn't help my self  from what i have read miller and a few of the others make welders that will run on the power you said ok Last edited by wello; 03-11-2008 at 08:47 AM.Creative metal Creative metal Facebook
Reply:My Miller DVI2 will run on that no problem. Plus with the DVI2 you can run on 110 if that all that is avialable.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:An inverter will get you the most welding amps for 30 amp input.DavidReal world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2025-12-20 11:32 , Processed in 0.090692 second(s), 18 queries .
