Pics from welding clinic
发表于 2021-9-1 00:52:47 | 显示全部楼层 |阅读模式
We had a blast.  There were 4 of us, 2 machines running most of the day.  We did tig on carbon steel, Tig on aluminum in all positions, Lots of stick, mig, pulsed spray mig of course, Plasma cutting, and Oxy torch welding.  I am glad there were not too many because it gave me more time to work with each one.  I also almost finished the grill.  2 had never run stick, 3 had never welded with an oxy torch, one had not tigged, 2 never used a plasma, or mig.First, we started on some rusty plate that couldn't even be cleaned up with a grinder, so I got out a piece of 1/2" and some fresh out of the oven 1/8" 7018 at 140 amps.  I THINK this was Ryan's (G1K here)This is Eddy's first time TIGSome Oxy Torch welding with R45 rodAnd My son Mig welding the 3/8" round stock for the grate.Last edited by David R; 03-22-2008 at 08:04 PM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Eddie who had never run a mig before started with the SP100, then the V350.Ryan using the arcmaster 185 on aluminum.  We proved again that 185 amps is just barely enough to weld big pieces of 1/4" aluminum.  We used pointed red and gold tungsten.  The gold seemed to keep a better tip.The grill.  I did the inside fillet in the back which is 24" in 30 seconds with .030 wire @ 1,000 ipm in pulsed spray mode.  92/8 gas.Guess who the grill is for?  This is Ryan's handy work.  He drew the letters and tigged it with stainless.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:My son ran the top bead with 5/32 6010, I ran the bottom one.Ryan took more pics, hope he posts them later.David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Here are the pictures from my cameraBreaking a cast iron part.. why you ask?  So we can weld it back together of course...The breakBeveling the broken piecenext...Last edited by David R; 03-23-2008 at 08:57 AM."I heard that!!"
Reply:let's try that with out the two copies of pictures...1. a root pass2. a stitch pass (only partial at the top)  .   never mind the other weld, no filler on part and it cracked upon cooling3. Eddie's mig.  I think that looks great.4. overhead tig on Aluminum5. Sticknext Attached Images"I heard that!!"
Reply:An finally the grillAnd a big thanks to David, thanks for having us and showing us the way..Ryan Attached Images"I heard that!!"
Reply:look fun... wish I was in your area... I mean country...Unit in my fab shop dept:my good hand and team that trust me...A lone welder make art... a village full of welder make Miracles...
Reply:Sure is a good time 'Aint it??...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Looks like you guys had a good time, The writing on the grill turned out sharp!
Reply:Alrighty, great that folks can get together like that.
Reply:I like that grille, came out nice .MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Man thats is so cool. I wish I could have made it.  My hat is off to all that set up these clinic's and gethering. You guys are Super cool Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:Looks like a good time was had by all.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Originally Posted by jamlitMan thats is so cool. I wish I could have made it.  My hat is off to all that set up these clinic's and gethering. You guys are Super cool
Reply:I hope there was a lot learned there!  An excellent idea and a good time to boot?  Sounds like a winner!Have a Jeep Cherokee?  Click Here!
Reply:Nice pics.  Looks like you all had some fun. weld it like you own it
GMT+8, 2025-12-20 11:31 , Processed in 0.091817 second(s), 18 queries .
