Grinding off welds
发表于 2021-9-1 00:52:42 | 显示全部楼层 |阅读模式
Is it fastest to just grind them with an angel grinder? I plan on grinding them off and then reusing the metal.Is this possible?This is probably a stupid question. I am sorry.
Reply:What are you taking apart and what other tools do you have available?If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:Sure it's possible. It can not go on indefinitely, but it can be done.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:you betcha its possible. most of the things i built when doing saw mill maintaince were out of scraps, thats all we had most of the time. for the big honking welds you can take them down with a cutting torch then finish with the grinder, its quick and easy (as a suggestion). as for quality and looks of the project, it depends on how much pride you take in it all. recyclers do it over and over.Nothing Ever Got Done By Quitting, Never Give Up.
Reply:yes...Unit in my fab shop dept:my good hand and team that trust me...A lone welder make art... a village full of welder make Miracles...
Reply:I take all kinds of stuff apart with a grinder. I sometimes use a cutting disk sometimes a grinder is better. If you are in a hurry, oxy /accetelyne torch can make it a lot faster. depends on what you are taking apart.Guy_48Welding is an art......Millermatic 252Lincoln SP175PlusLincoln 225 AC/DC
Reply:It is structural tube steel. I don't want the quality of the metal to go away though.
Reply:just dont take off so much of the base metal when you grind or cut off the welds. Granted if its a recycle part and its been cut and welded several times in the same area then you will have a larger HAZ but typically people who recycle metal dont really care much about that effecting the base metal. It also depends on how big the part is and how much room/metal you have to work with ... If you use Oxyfuel to cut, just watch the Kerf, (depending on how much metal you have to work with) and be prepared to grind to a smoother edge usually.Certified Welding Inspector at your service...Level II Nuclear Welding InspectorLevel II Nuclear Electrical InspectorLevel II Nuclear Civil InspectorLevel II Ultrasonic Thickness Testing TechnicianCertified Smartass,and Wise Acre
GMT+8, 2025-12-20 11:31 , Processed in 0.093578 second(s), 18 queries .
