which setup?
发表于 2021-9-1 00:52:24 | 显示全部楼层 |阅读模式
I have a lincoln powermig 300 and love this machine. now i need to weld aluminum and dont know what to do. I've researched and found the Python-plus push-pull gun w/25 ft. cable for $1700. its suposed to be the perfect gun for the 300. Ive also checked out the lincoln precision tig 225 at $2000.price isnt really a concern , i,m just unsure which would be the best way to go.        at this time i have a project that requires me welding on an aluminum jeep body, along with radiator,fuel cell ,an other small parts. plus once i buy 1 of the above i'm sure i'll find other uses for it. looking for the pro's & con's between the 2 choices from someone that knowstiatony
Reply:no one have an opinion? if it helps any the alum. is between .110-.150tony
Reply:I would personally go with the precision tig myself. J.M.OIf it's too . get an office jobLincoln wp225g7 Lincoln 250 idealarcFrankenstein O/A set-up Weld-tech  tig set-upLincoln sp 175 plus profax  arc gouger
Reply:I would buy the tig if it were up to me.  For what is sounds like you are going to be doing I think the tig would excel.  Also not having to re-spool the machine, as well as change gas.  It will save time on jobs especially if you are working on one material and have a small job of another type material.  Just turn the machine and gas on, select a rod and weld it.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:The TIG. It will be a more vibration resistant weld and you will need it on that Jeep.
Reply:Originally Posted by BobThe TIG. It will be a more vibration resistant weld and you will need it on that Jeep.
GMT+8, 2025-12-20 13:03 , Processed in 0.122608 second(s), 18 queries .
