Anyone in the Southeast US that does CNC Plasma?
发表于 2021-9-1 00:52:23 | 显示全部楼层 |阅读模式
Guys, I have a job that I need about 100 identical pieces of 10ga or 3/16"  cut out.  If things work out then I can see a few hundred a year of these parts being needed.  The pieces are basically an eight pointed star with slots cut in the points.   I don't care if it is done with plasma or water jet as long as they are smooth and identical.  I have a pattern now or I can draw it off.  If you can do this or know someone who could supply this service please let me know.  Thanks  ~JacksonI'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Go to cnczone.com    They have a forum to get quotes for things like this. I am sure someone local to you can cut these out.
Reply:Check your PM's, I can help you out, the OMAX is always looking for something new to do.
Reply:If you dont find anyone on here to help, I can laser cut them for you n batches of 20insert thoughtful quote from someone else2000 Thermal Arc 300GTSW 3.5 hours1946 Monarch 20 x 54 Lathe1998 Supermax 10x54 Mill2004 Haco Atlantic 1/2" Capacity Lasernot mine but i get to play with it
Reply:forgot, I am in Nashville.insert thoughtful quote from someone else2000 Thermal Arc 300GTSW 3.5 hours1946 Monarch 20 x 54 Lathe1998 Supermax 10x54 Mill2004 Haco Atlantic 1/2" Capacity Lasernot mine but i get to play with it
Reply:chenry, i'll definitely keep it in mind.  I'm gonna see what I can work out with 500hp as he is only an hour's drive.  It will save me a good bit of shipping if i can drive to pick them up.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:hammac, chenry,Get to know TSPMAX on the Hobart board.He's in Shelbyville/Murfreesboro and has been of great help to me.  I consider him a good friend and general, all-around good guy.Dano
Reply:im well fixed, i have a haco 1/2 laser less than 10 minutes from home at a former employer  and great connections with the local steel supplier , sisken steel ( thick plate burning ) and loftis metals for aluminum and stainless waterjet work and steel plasma under 3/4.I am looking into the " Steel tailor " machine. Price is right and i think i could actually sell 4 or 5 and get my unit for free. hesitant because i dont know anyone using oneinsert thoughtful quote from someone else2000 Thermal Arc 300GTSW 3.5 hours1946 Monarch 20 x 54 Lathe1998 Supermax 10x54 Mill2004 Haco Atlantic 1/2" Capacity Lasernot mine but i get to play with it
Reply:Siskin steel can do thin plate with their Hypertherm HyDefinition plasma systems.....why don't you just get Sisken to do them for you?Jim Colt
Reply:Originally Posted by chenry ...I am looking into (buying a) machine. Price is right and i think i could actually sell 4 or 5 and get my unit for free....
Reply:That is a thought, but I'm not familiar with siskin steel.  Where are they located?I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Chattanooga......I saw one of the posters mention that they get their steel from them....and I know they do custom cutting as I had a hand in selling them their plasma systems over the years!jim
Reply:Yeah, Siskin is here. They used to be a pretty good yard. They are kinda way overpriced nowadays.Miller EconotigCutmaster 38Yes ma'am, that IS a screwdriver in my pocket!
Reply:ALMA machine services in Carrollton has a CNC machine...no clue about prices.remove the AT and DOT and replace with @&.alma707(AT)aol(DOT)comSmithboy...if it ain't broke, you ain't tryin'.
Reply:Check with Coosa Valley Steel in Rome GA. I think they do, but I amnot sure.
GMT+8, 2025-12-20 13:02 , Processed in 0.093290 second(s), 18 queries .
