Welding up Caster Wheels??
发表于 2021-9-1 00:52:21 | 显示全部楼层 |阅读模式
I am building gauge wheels for a tractor implement I am building. Gauge wheels are more or least caster wheels. The sides will be welded to a top plate where it will pivot. I want the sides square with the top plus I want the axle shaft square also. Should I put a spacer in the lower end and tack in to keep the lower part from warping when I weld it in??Thanks,DanMy instructor said someone will catch on fire during class...He wasn't joking!!
GMT+8, 2025-12-20 13:08 , Processed in 0.090660 second(s), 18 queries .
