drill master 4 1/2" grinder
发表于 2021-9-1 00:52:17 | 显示全部楼层 |阅读模式
Has anyone used the drill master 4 1/2" grinder from harbor freight. This grinder is on sale & i will be using for light duty work.the grinder is 4.2 amps which is strong enough for my use.aluminum housing with ball bearing & 90 day warranty on sale for $8.88 with 90 day warranty.thanks for your help
Reply:I have 5 of them.  Each with a different wheel.The only problem I have had is brushes, so I ordered 10 pairs from the parts line.
Reply:I have one that I have used for 2 years now doing metal prep for fabrication and also for doing body work, and as a cutting tool for about half that time. No problems yet.Think I'll get another one for that 8.88 price.Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
GMT+8, 2025-12-20 14:36 , Processed in 0.093986 second(s), 18 queries .
