What size tank for a MIG welder?
发表于 2021-9-1 00:52:15 | 显示全部楼层 |阅读模式
So i'm finally getting around to getting a tank since I have several projects that I have put off and I need/want to get them finished.  What size tank would you all recommed?Right now I have a spare tire carrier designed as well as rear tube fenders for my Jeep.Thanks have a great day.Tyler03 Jeep Wrangler, Lifted, Locked 36sHobart 187
Reply:Tyler,I would get the largest one you can get.....my reasoning is simple.....a 40 cuft is $120 a refill is $20,a 90 cuft is $135 and a refill is $30 a 160 is $150 and a refill is $40 so for $30 more I can get a cylinder that is 4 times the size and cost only twice to swap for a filled one...so the savings in refills alone will pay for the larger cylinder quickly.....and as far as a lease....not for me as I have two LWS close so if I want to take them to one or the other then I can.Mike
Reply:i get 245 or 381's if i can find them
Reply:Thanks for the advice.  I will have to go sometime this week or next to get one.Tyler03 Jeep Wrangler, Lifted, Locked 36sHobart 187
GMT+8, 2025-12-20 16:08 , Processed in 0.089342 second(s), 18 queries .
