Need help finding a tool.
发表于 2021-9-1 00:52:13 | 显示全部楼层 |阅读模式
I'm looking for a sanding pad cutting tool. Kinda looks like a can opener. You put your 9" pad on and turn the handle and it cuts it down to what ever size you want, mounts oh the edge of the work bench. Any one know where to find one?If I Can't Weld It!-----It Can't Be Welded!
Reply:Not sure what you are describing. I have used an old hacksaw blade screwed to the side of my work bench to "cut" sandpaper sheets. Same idea as the tear strip on a box of saranwrap or wax paper. Slide under the blade and tear where you want to cut. I had a friend who used an old paper cutter, cut with the grit down.
Reply:Check out http://www.mytoolstore.com/milwauke/grndpap.htmlhttp://www.associatedfastening.com/pg8.htmGood luck.awright
Reply:http://www.fastenal.com/web/products...h8?sku=0200184Clarke 130EN C25Lincoln 225 AC Stick(1968)Smith O/A RigHF 4X6 Red BandsawBlack & Decker Pro Chopsaw16 Speed Drill PressSpeedglas XL HelmetHarbor Freight Stuff
Reply:WOW!  Thats the tool, Thanks for the help and fast reply!If I Can't Weld It!-----It Can't Be Welded!
GMT+8, 2025-12-20 13:08 , Processed in 0.073261 second(s), 18 queries .
