It's Been Asked...
发表于 2021-9-1 00:52:09 | 显示全部楼层 |阅读模式
Can you repair watercooled tig hoses?Yup..Here is a water in near the torch repair..Gas line repair with a drinking straw under the tape..Water out..No biggie..Lots of duct tape..Not pretty at all..Burn thru the "protective" hose cover during a class awhile back..Unless you "Burn it to the ground" like I have done before you can use tape and anything to fix this stuff..And it don't leak anything either.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I have cut brass tubing and used it as a insert then twisted wire around each end...small worm clamps work tooJonesy
Reply:You wasted a beer straw on a torch hose?!?!  9-11-2001......We Will Never ForgetRetired desk jockey. Hobby weldor with a little training. Craftsman O/A---Flat, Vert, Ovhd, Horz. Miller Syncrowave 250
Reply:WOW.....Who knew you guys watched Red Green down there....Got any photos of Possum Lodge?"If the women don't find you handsome....At least they'll find you handy." - Red GreenLast edited by Black Wolf; 04-26-2008 at 09:12 PM.Later,Jason
Reply:Originally Posted by Black WolfWOW.....Who knew you guys watched Red Green down there....Got any photos of Possum Lodge?"If the women don't find you handsome....At least they'll find you handy." - Red Green
Reply:Wouldn't know abotu water cooled, real men use air ;D   I'd rather be hunting........USE ENOUGH HEAT.......Drifting around Aussie welding more pipe up, for something different.....wanting to get home.
Reply:One wrap of black plastic electrical tape with super glue makes a good patch for a TIG hose. I had an old torch that I got with my former Lincoln TIG that needed six or seven such patches. It was still working 14 years laer when I traded it in.
Reply:Red Green is greatThe difference between art and craft is the quality of the workmanship. I am an artist.
GMT+8, 2025-12-20 13:02 , Processed in 0.070851 second(s), 18 queries .
