lincoln 135 vs miller 135
发表于 2021-9-1 00:51:37 | 显示全部楼层 |阅读模式
As far as 110 machines go, which one of these is the better choice ? I am looking to buy a used machine, so what types of problems should I look for in them on my search. I am going to use a bottle, and primarly weld .095" to 3/16" steel. ( sandrail stuff )
Reply:I'll start out with the standard comment that 110v machines really don't do 3/16+ well. Read the sticky on 110v migs and look at the threads listed there. A 220v machine would most likely be a better choice.With that said and out of the way, I think that either machine in good working order would be similar to the other. Since you are looking at used, that will limit you to whats available rather than picking a specific machine. I'd stay away from the cheap imports if I was you. At least with a lincoln or miller you can get parts in the future.Find out why the person is selling the machine used. Have they been using it well beyond its capacity and getting a bigger machine? Not uncommon. They may have really been pushing the duty cycle and putting some hard use to the machine even if it looks clean. I'd try and see if you can run a few beads with it to see how it works. I'd be leary of buying a machine I haven't had tested or used.
Reply:Ford, Chevy, Dodge.  I would guess that on a sand rail the 3/16 parts are going to be gussets and such, if that is the case, bevel the edge and put on several passes. You will be plenty stout. I would agree with everything DSW had to say except that if the machine welds good for you, the past duty is probably negligible and not an issue. A 110 will normally not see heavy use but maybe I am the optimist. I'd say if it welds good for you then get it.Bill
GMT+8, 2025-12-20 12:27 , Processed in 0.086721 second(s), 18 queries .
