Lincoln 180T
发表于 2021-9-1 00:51:37 | 显示全部楼层 |阅读模式
I have a lincoln 180T mig welder & what i would like to know about  the heat settings are A,b,C,D,E can someone tell me what volts each one represents.thanks for your advice.Last edited by wheelerbuffy; 04-19-2008 at 12:57 AM.
Reply:Each one will put you in a range, relative to the other.Go to www.lincolnelectric.com and get your free owner's manual.  It will give you the curves for each setting.
Reply:There should be a decal inside the wire drive door that tells you what each one means, and what its ideal for.The Welder Shop has great deals and reviews on Hobart, Miller and Lincoln Welders.
GMT+8, 2025-12-20 12:28 , Processed in 0.166688 second(s), 18 queries .
