Anyone heard of 320 s.s. ?
发表于 2021-9-1 00:51:33 | 显示全部楼层 |阅读模式
I have a job to tig weld what they claim to be 320 stainless plate. I cannot find a listing for it, let alone find a wire for it. Techalloy makes a 320L wire that says its for castings but this is definately not cast. Also while we are at it , what wire do you recommend for Inconel, I have techalloy 625 - Is that the right match?
Reply:this might helphttp://engineers.ihs.com/document/ab...KIIBAAAAAAAAAA
Reply:Not familiar with 320, did find this on Matweb, Universal 320 produces a fully austenitic deposit for welding Carpenter Stainless No. 20Cb-3 (wrought form) or Durimet 20 (cast form) or similar alloys. The 320 alloy was developed to give improved resistance to the corrosive action of sulfuric acid.  AWS E320-15,16 http://www.matweb.com/search/DataShe...D=19597&ckck=1For the Inconel, you need to know what alloy of Inconel you have, 600, 625, 718, etc.  http://www.matweb.com/search/QuickText.aspx
GMT+8, 2025-12-20 12:24 , Processed in 0.092479 second(s), 19 queries .
