Welding steel outrigger plate to steel column, less weld
发表于 2021-9-1 00:51:31 | 显示全部楼层 |阅读模式
Hello guys,We are welding  a 6" (horizontal) X 8" vertical 1/4" steel plate to a steel column.  The initial plans called for two horizontal welds one on each side of the clip.  The latest plans call for a full weld all the way around all 4 sides.  Will the initial assumption work under these design reactions:V= 140 lbT= 2884 lbM= 1262 ft-lbWe are using E70xx class electrode to weld.  Due to budget restrictions, we are requesting for a deviation from the latest plans.  In case the horizontal welds are not enough, will welding 4" all 4 sides work??.Thanks in advance for any ideas or advice you can provide.
Reply:you might get a better response at this forumhttp://www.eng-tips.com/threadminder.cfm?pid=679
Reply:Thank you very much for your advice.  I'll give it a try.
GMT+8, 2025-12-20 12:18 , Processed in 0.156188 second(s), 18 queries .
