What to do with this stuff?
发表于 2021-9-1 00:51:23 | 显示全部楼层 |阅读模式
Steel bars, 20 each at 1.5"x4.5"x26" powder coated, each weighs about 50lbs.They were used as counterweights on a construction project. I just couldn't watch then being dumped in the scrap metal dumpster.  Maybe tractor or implement weights? Any suggestions not referencing any specific orifice would be appreciated.
Reply:Could be used for the feet on a small work table or tool stand. They would definitely make it stable. Cheap cruise control? Throw one on the pedal and go.
Reply:If you can take it then take it..You will wish you did one day when you chose not to.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
GMT+8, 2025-12-20 12:42 , Processed in 0.093127 second(s), 18 queries .
