Suggestion on better material for hinges.
发表于 2021-9-1 00:51:20 | 显示全部楼层 |阅读模式
http://weldingweb.com/vbb/showthread.php?t=21678I showed the hinges in the above thread to my client.  They will work for our purposes.  However,  I was,and Mondo raised, concerned about galvanic reaction between the ss and Al.Any suggestion on material to improve the design? The awning is aluminum.  I have 32 more to make.  ThanksLast edited by tapwelder; 05-28-2008 at 07:04 PM.
Reply:Will the hinges be powder coated prior to the ss washers installed?A good guess is better than a bad measurement
Reply:hinges will be installed and locked in place when powder coated.Last edited by tapwelder; 05-28-2008 at 07:04 PM.
Reply:In that application I wouldn't be too concerned , yes there it a reaction but remember all screws used in ally assemblies are ss.There are nylon washers around and ally washers but neither sound applicable.A good guess is better than a bad measurement
Reply:Stainless..But they will be powdercoated..So mild steel would be OK too..Less $$$$...zap!Last edited by zapster; 05-28-2008 at 07:22 PM.I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by tapwelderhttp://weldingweb.com/vbb/showthread.php?t=21678I showed the hinges in the above thread to my client.  They will work for our purposes.  However,  I was,and Mondo raised, concerned about galvanic reaction between the ss and Al.Any suggestion on material to improve the design? The awning is aluminum.  I have 32 more to make.  Thanks
Reply:Originally Posted by zapsterStainless..But they will be powdercoated..So mild steel would be OK too..Less $$$$...zap!
Reply:Originally Posted by Donald BranscomStainless and Aluminum get along ok together. Those two metals are used on sailboats in close proximity all the time.
GMT+8, 2025-12-20 14:21 , Processed in 0.092027 second(s), 18 queries .
