need help with my linde
发表于 2021-9-1 00:51:16 | 显示全部楼层 |阅读模式
i got a linde water cooler wc-5a, p/n 953564 for my newest purchase ( of course the cooler was used),it was a dirty mess so i decided to clean it up, and since it came with a pump rebuild kit and the front seal looked to be leaking, i would install it.heres the problem i fixed it so good it will not pump and i need/want a new pumppump part # is677475 please help me find one, especially at a reasonable pricei know ruin a steel ball with a rubber mallet...thanxI wonder if I will be spanked for this one too!?!
Reply:you might try loosening up the bolts on the end of the pump a little mine also did that and i loosened the bolts a touch and it started to work. do you also have a linde welder. just wandering cause i do and im looking for a couple parts.millermatic 210miller 375 xtreamlinde power supply hda 200 tigcentury 110 flux corelincoln buzz boxlet the work speak for itself i do!!!check mine out at http://www.eyepoppincustoms.com
GMT+8, 2025-12-20 14:20 , Processed in 0.123369 second(s), 18 queries .
