Help ! Where can I find a "saddle" to mount #2 Argon tank
发表于 2021-9-1 00:51:05 | 显示全部楼层 |阅读模式
I'd like to mount my #2 argon tank on the side of a new welding cart. Does anyone know of a "side saddle" style contraption to allow the tank to "piggyback" on the side of a workbench/cart?I guess this might be something equivalent to a fire extinguisher mount ??Thanks !
Reply:Your probably gonna have to fabricate something.  A 6" piece of channel iron with a piece of 3" flat iron welded across the bottom, and a couple hooks on the side, to attach a ratchet strap to hold the bottle in the channel would work for your application.  It would be an easy project as well.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Thanks for the idea, it's much better than mine. I was going to "capture" it into the corner of some 3" angle stock. Your idea will serve much better as far as providing better "envelope" or "shroud". Thanks !
Reply:Couple brackets:http://brwelder.com/indextemplate.cf...ubCategory=153Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2025-12-20 14:20 , Processed in 0.380315 second(s), 18 queries .
