drive rolls for mig wire
发表于 2021-9-1 00:50:51 | 显示全部楼层 |阅读模式
I am using .025 drive roll with .030 wire because i did not receive a .030 drive roll with welder.do i need to get the right roll or will the .025 work ok with this mig wire. welder is a lincoln 180t which i have had about 2 months but untill this week have only used the  fluxcore wire.now i am trying the 75/25 mix with mig wire.i did receive a .030 roll but it is for the fluxcore wire or the knurled roll as it's called in manual.thanks for your help.
Reply:The manual has a page with "What comes with.." and lists the drive roll as ".025-.030"  although later in the manual it just states it as a .025 roll.Don't see anywhere to order a .030 drive roll so I guess the .025 is for .030 wireEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:The .025 drive roll will work fine for .030 wire.  It's all I have ever used.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:I really do appreciate the respones i got about the drive roll.     Thanks alot
GMT+8, 2025-12-20 14:36 , Processed in 0.096864 second(s), 18 queries .
