galvanized steel
发表于 2021-9-1 00:50:49 | 显示全部楼层 |阅读模式
How much more % wise is it more than cold roll or hot rolled?
Reply:do you mean price wise?M Fed
Reply:Generally you don't buy galvanized stock.  You but your stock metal, fabricate/weld it into parts, THEN galvanize it, because A) you'll have to spray your welds down with that nasty zinc based paint after you weld galvanized otherwise it'll just rust, and B) welding galvanized SUCKS!  Dirty, dangerous fumes, clogs up your nozzle fast, etc, etc...If you have a truck you might be better of buying regular black steel and make up what you want, then take it to have it galvanized (if it's tubing of any kind, make sure you drill holes in it in the right places to allow the liquid to escape during the galv. process)."A winner isn't someone who doesn't lose, a winner is someone who doesn't quit."
Reply:Yes I mean price wise. Sorry.Which is better for corrosion protection? Galvanized or powder coating?
Reply:Originally Posted by pyroracing85Yes I mean price wise. Sorry.Which is better for corrosion protection? Galvanized or powder coating?
Reply:The American Welding Society did a 19 year report on galvinized steel boats.The results were very good.
Reply:Originally Posted by BrettYou would have to consider the application .Generally Galvanizing. There are Zinc sprays applied commercially that out perform hot dipping. Galvanizing can leach through Powder Coating and void your warranty.
GMT+8, 2025-12-20 13:03 , Processed in 0.071373 second(s), 18 queries .
